Need a little help to get this piece of trim off. On the rear door- on the rear of the window glass there is a triangular piece of plastic rapped by a thin weatherstrip. How do you get this piece off.
Thanks,
Ken
If you are talking about on the inside of the door....You have to carefully release the push pin retaining clips(pictured below) you then can pry up on the window seal and the plastic trip piece can turn and pull out.
