I'm having trouble installing a RS730 alarm system on my charger. I have the ads-al-ca idatalink module which is wired correctly and was programmed correctly. Now when I try to program the alarm system, I don't get any feedback from the alarm (siren or led). I have the module and the alarm system connected via rs232 cable.
I tried to reset the module, but the light isn't working. I don't know if it's because it's already program or just waiting for the alarm to be programmed. When I leave my doors open and connect the yellow wire from the idatalink module, the door chimes until it's closed, so I guess the module is working.....
Is there anyway I can hook the alarm up using basic connections to see if it's operational?
Discussion Starter #2
Are there more wires I'm suppose to connect from the alarm system other than the power, ground, and the wires on the idatalink install guide?
