Hey guys i have some issues going on is there a easy way to tell if its my ecm on the firewall or my front control module on the fuse box i get the bas and esp light and a bunch of other lights as well but i also cant connect my obd2 reader when its wigging out to scan for codes it also will sometimes mess with my door locks while i am in the car it starts and runs but sometimes it wont it will just start and die before you can even get it in drive
Only way to test the FCM is with the diagnostic system used by the dealership. Apparently the dealership you went to does not have a qualified technician ... otherwise, they would have been able to isolate the problem. It could be the FCM, a wiring harness issue, ground problem or a CAN Bus termination problem. Is there another FCA dealership in your area?
The dealership i took it to said that they couldn't get it to replicate but i literally got it home and boom it did it again i am currently looking into another dealership at the moment i did however pull some fuses that run my pcm in the front fuse box and switched them with a step up so went from a 5amp to a 10amp and i think from the 2 15 amps to a 20 amp and did a gauge cluster reset and very oddly the lights cleared them selves not sure if that is a good thing or if it will short out what is the problem
