I GOT A PROBLEM! I HAVE A SET OF 24X10 WHEELS WITH 275/25/24 TIRES BUT THE LUG PATTERN DOES NOT MATCH. I SAW A SET OF WHEEL ADAPTERS FROM UNIVERSALCARLIFTS.COM THAT WOULD CONVERT THE LUG PATTERN TO THE ONE I NEED. THE WHEEL ADAPTER IS 1" THICK...WILL THIS WORK? IS IT GONNA STICK OUT TOO FAR? WILL IT RUB WHEN I TURN? :4-dontknow:
100k Mile Club
2012 Dodge Charger SXT Blacktop
I had to use those on my last truck and the wheels stuck out alot...............I doubt they would look good or even work in your situation.
Can you return the wheels for the correct bolt pattern? I wouldnt recommend adapters but that is just my opinion.
