2012 Dodge charger with right rear camber "not meeting alignment specs." I need a +1mm repair kit... But idk what that means. Do I need a whole new camber link? Or do I need new bolts? The paper reads as follows:
"Rear Camber
If individual rear camber is found not to meet alignment specifications, repair camber links are available in plus or minus one millimeter (1 mm) lengths.
A plus or minus 1 mm repair camber link will change camber approximately 0.5-0.7 degrees in the preferred direction."
I need plus 1mm... So what do I need in terms of materials?
Thanks in advance!
"Rear Camber
Thanks in advance!
