1 - 1 of 1 Posts
The motor in my 2006 3.5L went out so I swapped it for a rebuilt 2007 3.5L. A few things were different, such as the wiring for the camshaft sensor, but I figured most of it out. My problem now is the upper intake. The intake for the 2007 has 5-pin sensors for the intake manifold actuator and the runner control valve. The 2006 had 2-pin sensors on each. My wiring harness is also set up for the 2-pin. Is there anything I can do to make the 2007 5-pin upper intake compatible with the 2006 2-pin wiring harness?
1 - 1 of 1 Posts
