On the way back to Austin from South Padre Island when half way through the trip I hear a ding...look down to find the check engine light on...
Awesome... 200 miles to go, what damage am I causing...
Found a check it yourself process on the forum, performed and got a 0406 code...Thought I read somewhere that a 0406 was a 02 sensor...
Does anyone know if this is valid and if so...What the process of resolving this issue might be?
Thanks in advance...
H-D 883 IRON
P0406 is EGR position senor circuit high. The most likely suspect is the EGR Valve. This may be covered under your emissions warranty.
