I have a 2007 Dodge Charger and I am having an issue with the turn signal on the drivers side front. I have replaced both turn signal bulbs (front and back) Cleaned the bulb sockets. The turn signal flashes but dim and when the headlights are on the turn signal quits flashing all together... any ideas what would cause this?
HELP!!!!!
Sounds like the voltage to that socket is low due to high resistance. Check the wiring harness/connector for that circuit. Look for loose connections, fraying, corrosion, etc... anything that would contribute to high resistance. Make sure there's a good ground connection.
