Quick question. The front speaker on my wife's charger se went out. I am looking to replace the amp as I have already checked the fuse and that wasn't it. I was going to run to the junkyard and try and grab one. Is there any interchangeable models that I can use in the event they don't have the exact year, make and model?
As far as I know the 2012 through 2014 models are interchangeable. The main difference was how many speakers and whether the system has a amplifier.
The base speaker system includes six speakers.
Two 8.89 centimeter (3.5 inch) diameter midrange tweeters located in the instrument panel.
Two 15.2 X 23 centimeter (6 X 9 inch) diameter speaker located in each front door.
Two 15.2 X 23 centimeter (6 X 9 inch) diameter speaker located on each side of the rear shelf.
The premium-1 audio system includes six speakers and a amplifier.
8-channel 276 watts amplifier located under the instrument panel to the left of the steering column.
The premium-2 audio system includes nine speakers and a amplifier.
Three 8.89 centimeter (3.5 inch) diameter midrange tweeters located in the instrument panel.
Two 15.2 X 23 centimeter (6 X 9 inch) diameter speaker is located in each front door.
Two 8.89 centimeter (3.5 inch) diameter midrange tweeters located in each rear door.
One 20.32 centimeter (8 inch) DVC subwoofer.
12-channel 506 watts amplifier located under the instrument panel to the left of the steering column.
So I wanted to find out some info on my car , What I found out from Dodge was 84,000 chargers were made in 2014 of that 2373 were 100th anniversary and mine was , See attached from Dodge Dear Customer:
Case #: 29942873
VIN: 2C3CDXCT1EH277537
Vehicle Description: DODGE CHARGER R/T RWD FOUR...
I recently purchased a former police car 2014 5.7l Charger. I believe when they removed all of the police instrumentation they just went through and cut wires they thought had something to do with the instruments but ended up cutting random unrelated wires as well (had to completely rewire tail...
So I will be honest I was doing some heavy acceleration Just to test out the tire grip and brake stopping power lol 😂 when all of a sudden smoke came from the from passenger wheel well I thought it was just tires still smoking but how was I wrong when I stopped and opens the hood I got a strong...
Hi All - 2014 SXT-Plus - This morning the Yellow check engine light went on - yellow - solid - no blinking. Normally, I would think this is just an emissions check thing, and blow it off until tune up time, but the oil pressure readout in the Engine Info view is pegged at 99 psi at cold idle...
