941 - 943 of 943 Posts
Does it NEED to be the Android version? Many of us have the PC version.
Also keep in mind there is a glitch with certain mileage entry numbers, for instance, if you are trying to put 83704.4 in it may not work, but 83700.0 will. I had that issue on my buddies car, it would cycle and not change the mileage, but after just rounding down a bit it worked.
I come bearing fix! Mileage fix released for PC! Simply extract the folder anywhere and, provided you are on the same device, use the same activation code you were sent originally.
Edit: to make it work, you may need to start the process again while on the Continental screen. I got mine to work that way.
