1 - 11 of 11 Posts
Hello all I have a question that I hope you all could help me with
119474
as you can see I have a 2018 Dodge Charger r/t with the factory blacktop wheels I am running 245's tires which is what it came with .. looking too upgrade to 275's all around I see a lot of folks just do the back tires would it possible to run all around ? with no rubbing issue ill upload a pic so you can see the wheels I have incase I was wrong ... please help a friend out ?
2017 Charger R/T Blacktop
Welcome from AZ.
WELCOME to the forum! What's the width of your present wheels? You need at least 9" width for 275/40 tires. Factory with 275 is 9.5", but 9" works. 8" not so much.
Welcome from Colo! I'm running 275's all around on my Scat and no issues at all...and I believe 275's are the max width one can run up front without being a Widebody....
Reactions: mofogo
I have a Charger Daytona with 9" wheels, and 275/40/R20's fit just fine. I went with Atturo AZ850's for about $475 mounted, and I am very happy with them so far.
Verify the size of the wheels by the stampings on the back. Tire Rack says ok to 275/40 on 9" wheels, so that's good enough for me.
Welcome to the Z, from Pittsburgh! I see you got your 275 tires answer. Always good when it's a consensus! Go for it!
Reactions: SUPREME213
1 - 11 of 11 Posts
