Left picture side 3.5 intake has MTV on passenger side (left in photo) and SRV on driver sided (right). Right photo has only one, which one is it can anyone confirm?
So I had 2007 charger 2.7, after engine dies I swapped 3.5 and had no problems for half a year, however I always had fault code regarding MTV and now because I have problems with new engine I want to clear all codes so we can find whats wrong. 2.7 intake has only one valve - MTV on passenger side (5 wire pin) my new 3.5 engine had MTV and SRV with two wire pins. We connected the wires according to diagram, but I had MTV code (because there were some wires not connected to anything because only two wire connector on new engine so no idea if it worked). SRV did not throw code, but probably it did not work at all, because my ECU was not designed to have it. So now I found 3.5 intake with only one valve and 5wire pin (like my old engine) So if its MTV it should plug in and work, but because its on another side I have no idea if its MTV or SRV there
The 3.5L V6 in the Charger has the two valves
Manifold Tuning Valve (1) and Short Runner Valve (2)
118693
Illustration above copied from Dodge Charger Service Manual
