So I just picked up out of 2010 challenger I counted the splines on unit and came up with 31 rock auto is sold out or rebuilt ones what part or axles can I use according to the dealer any srt8 should work but that can’t be the case if the inner spline is 30 any help would be greatly appreciate also what is the spline count on the 226 axle outer for the wheel bearing hub
I don't know about SRT's but your hubs should be 32 splines. Open 215 cast iron diffs inputs are 30 splines.
Commonly, when one goes from open diff to getrag the hubs are the same but axles are more robust and have different spline count. Cannot swear but 27 splines I believe.
You need a longer bolt for the forward mount.
Yes I have the longer bolt but trying to figure out the hub and axles the 08srt8 hubs are 27 spline count that I got for my brembo swap but I can’t find any info only mopar part numbers for axles and hubs but not the info on lengths of axles and spline counts
Discussion Starter · #6 ·
I ordered the axle hubs so when I receive them I will put the information on spline count
