Concerning a 3.93 challenger getrag Differential swap....
Can we use a whole challenger rear assembly diff, axels, & hubs ....
or ....
Will only the charger axels work for length on charger rear suspension of correct type, 233mm or 248 mm
I’ve been trying to dig out information on this for over two weeks now and I still have not come across anything you give me a definitive answer if the Challenger axles will be too long for our charger rear suspension?
Any info appreciated
Tony in Florida
Moderator
Double-check with High Horse Performance to be sure. However, on their web site, aftermarket axles from Drive Shaft Shop have the same part number and application for both cars w/Getrag.
Good lead... I call them and verified axles are the same for the Challenger and the charger with that 392 differential...
Thanks for your response and info
