I recently have found out I have a damaged front subframe from an alignment shop. This was before finding out I blew the piston rings in my engine. So I figure while the engine is getting pulled I could go ahead and have the front subframe replaced. So I looked around and I found one for pretty cheap and it’s not damaged. The only problem is it is from an SRT Charger. I was wondering if the 5.7L Motor mounts are the same as a 6.1L? Thanks.
Discussion Starter · #2 ·
I recently have found out I have a damaged front subframe from an alignment shop. This was before finding out I blew the piston rings in my engine. So I figure while the engine is getting pulled I could go ahead and have the front subframe replaced. So I looked around and I found one for pretty cheap and it’s not damaged. The only problem is it is from an SRT Charger. I was wondering if the 5.7L Motor mounts are the same as a 6.1L? Thanks. (I have a 5.7 BTW)
