I have a 2012 pursuit and I recently installed a 6.4 intake manifold. I'm looking to see if anyone has wired in this swap without the circuit boss and how you wired it up. Sorry if this is a noob question, I just want to get it right and not screw up my harness by doing it wrong. I have the MSD window switch on the way, just seeing if you can and how to wire in this RPM switch without the $90 fuse set up. Thanks
I was wondering the same thing since pursuits have a fuse box dedicated for the police accessories.
Use that. The whole reason for the cirkit boss (actual name from Painless wiring) is so that you aren't running a power source unfused. Anything OEM that supplies power to something in the car either has a fuse, breaker or relay as a safety in case something happens.
Google Dodge Charger Pursuit (your year) Upfitters guide. They give pkenty of info on everything and what has constant power, fused power, fused ignition sourced power etc etc.
