· Registered
Does anyone know how to hard reset the 8.4 Unconnet on 2013 charger ? I have tried holding down the hot and cold buttons I have also tried holding down the tuner and heating control buttons. My unit connect is flipping back in for through radio player and climate mode
· Registered
I have seen various methods on YouTube for entering Engineering Mode. The methods seem to be different for different model years and Engineering Mode was only accessible for certain model years. There's also Dealer Mode but I don't remember if it has a Uconnect reset.
You might try removing the fuse for the radio (fuse #37 in the rear trunk fuse box). Plug the fuse back in after ~15 minutes and see if it reset the Uconnect/radio. You can try the same fuse pull with the HVAC module (fuse #32).
Fuse Box Diagram Dodge Charger (2011-2019)
