Hello ,sorry for my english i'm french...
I have a problem with the air conditioning of my dodge charger rt 2006. Even after a reload, no fresh air ... no error code, fuses ok. Do you have an idea to help me? THANK YOU
can you hear the compressor click on...see the clutch lock up and turn the compressor ? if not , you can jump across the terminals on the low pressure connector on the accumulator and see if that get the clutch to lock up...if it does you need more refrigerant.. if not the clutch may be bad...you can use a DVM to check for power at the clutch connector...should have 12 v with air turned on..if there is power and the clutch does not lock....bad clutch..
