I’m having issues with my 2015 Rallye edition auto start. When I go to auto start it it reads “auto start disabled, start car to reset”. I have noticed if I drive the car, the auto start will work after it’s been off for a short time, but if it hasn’t ran for an extended period of time like a couple hours or overnight, then it won’t start and the message comes back on. I’ve replaced the battery in the fob and used the nose of the fob to start it, with no avail. She has no problems starting like a low battery issue, so I’m assuming the battery is in good condition. Has anyone had any problems like this?
You n]may have an engine code needing to be reset. Normally if you have a code it will show the service engine light but some codes don't. Get scanned for DTC's.
Yea never had the service engine light on, is there a way I can scan and clear codes, or do I need to take it to a mechanic?
Hi mhbbmanderson, I do apologize for the trouble you are experiencing with your Charger. If you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
DodgeCares
