1 - 8 of 8 Posts
Ok, i have a 08' R/T. just recently my auto UP fuction stopped working,
but the auto DOWN still works. BOTH doors are doing the same thing,
and started at the same time. Any ideas as to what would cause this?
Or where i should look first for a salution?
Greg
Staffing since 2008
You can try the auto reset. Press and hold them down till the windows are down, and hold them in the up position till the windows are up. Hopefully that will fix your problem
Yep what he said, i do believe you have to hold the button for a few seconds after they go up and down before they reset though.
doesn't this happen when the battery is disconnected?
Good Luck brother!
Discussion Starter #7
Thanks all, the reset woked! i figured it prob happened when i installed the
overhead DVD system, and un hooked the BATT..
THANKS again for the help
I will try this reset thing myself; they replaced my door hinges yesterday and I just found out that my auto down works, but not auto up.
1 - 8 of 8 Posts
