You can try disconnecting/reconnecting it to see if it resets but if that does not work it's what CE9311 said ... "replace it".
HFM (hands free module ... aka Bluetooth) is located under the instrument panel to the left of the steering column; mounted to the amplifier bracket.
Remove the steering column opening cover
Font Auto part Drawing Pattern Art
Disconnect the HFM electrical (1) and USB connectors (2)
White Line Font Parallel Diagram
Reactions: Abyyninte
