Anyone use boostane in their car? I have been and even though it's not very noticeable gain there is some. Car seems to run better. I'd say a good 5hp gain
I've always used Sea Foam...good for cleaning things out...and Lucus Oil stuff....don't know about that 5hp gain though!
Unless you are running more compression or spark timing, toss in air fuel ratio, for your current octane fuel to keep it from detonating before its time to, you don't need more octane.
Higher octane has a lower flash point. Its all about keeping it from detonating before its intended to do so.
In some cases replacing your fuel with a higher octane will reduce performance.
Some octane boosters claim you get another point increase. The fine print will reveal if you have 89 octane and apply their additive you get 89.1.
^^^ What they said. I would just run whatever octane the owner's manual suggests, unless you get a custom tune for 91 octane or the like. I see Boostane used by a lot of YouTubers, but I believe that may be because Boostane sponsors some. Just go with what you are tuned for, imo
