2007 Charger R/T, just under 202k miles.
As the title says- I got my oil changed yesterday, it was black. They put full synthetic high mileage mobil1 in. They also said my trans fluid was low, apparently I have a broken dipstick or the wrong one. They measured with theirs, it was at the 20 mark and the tech said it should be at the 45mark so they topped it off. The previous day I got a CEL for P3441, I looked it up and one of the possible causes could be oil or the solenoid for cyl 6 MDS is bad. Since I got the car just over a week ago and I didnt know the last time the oil was changed, I had it done. They did an engine flush on the oil as well, or so they claim.
Left the shop fine that day. I have that diablo obd2 thing that disables MDS, so I used it when I left, thinking if I disabled MDS I wouldnt get the CEL for the MDS code. This morning I left for work, CEL back back on even though I used the diablo thing, whatever, kind of expected. But then the car didnt want to shift into the next gear, like it was delayed, and started running like it was misfiring and just in general like poop. Got on the short highway, same delayed shift and running bad like a misfire, but then smelled like burning oil and I got oil smoke in the car (windows down) and I could see some behind me. Smoke went away but the smell didnt, almost smelled like something was melting or on fire. Made it to work backed into my spot and it nearly stalled, its running rough like it has a cam almost.
P3441 (deactivation/intake valve control circuit/open) came back as pending and stored, and now P1416 (air sys bank 1) shows as pending. Google shows both those codes for MDS cyl 6.
At this point Im assuming I need to get that MDS solenoid replaced, but would that be causing all these problems, or am I looking at needing a new engine?
