Hi Guys
2011 R/T
I do not get the chance too often to go WOT, but when i do i get this awful burning smell for a min or two then its gone. is it my cat's starting to finally go? 194xxx km
Or do i just need to do some runs at the track to burn everything out?
Thanks
Rob
Sounds like you may be burning something off the hot exhaust, like the "nagging" NAG1 trans fluid leak from seal, or maybe other leaking oil/fluids from leaking engine gaskets/seals? I had my NAG1 defective German seal replaced shortly after new, and several years later the same bad design began to leak again...:( Could sometimes smell it burning off the hot exhaust. Leaked just enough that you had to add maybe a 1/2 qt. every couple months.
