1 - 1 of 1 Posts
I did a burnout in my 3.6. Car went limp. Would not shift in gear. Check engine came on. Pulled transmission realease lever. Car finally went back in gear. Happened in feb. went to advanced code came back for o2 and oil pressure sensor. Changed both. Got a ntk o2. And mopar oil pressure sensor. Codes went away for 02 permanently. Oil pressure sensor code continues to come back. Oil pressure sensor continues to give check engine I have changed 2 at this point. Not sure if I need a new oil pump or oil filter housing. Need help has anyone encountered anything close to this?
1 - 1 of 1 Posts
