so i got the cheap grille with the plastic grid and i was wanting to switch it out with honeycomb from ebay by mopar... do i just have to pop out the old and clip in the new or how does it work
Well its a pain to do. You have to remove the front clip, remove the grille insert, replace it and then put it all back together. If you order the grille on ebay from a dealer like I did, it will come with destructions. You have to remove the skid plate under the bumper, then remove the 8? plastic rivets on top of the bumper, then remove the 8 bolts that hold it on to the car. Took me about an hour to do. To get to two of the bolts that are way in there you need to take the tires off the front and you will need a 10+ inch extension to get to those two bolts. Here is the link with destructions. http://www.chargerforumz.com/showthread.php?t=1385
i think i could do it with out removing the whole front???
I couldn't get my arm in there enough to turn the screws that held in the grille.
i tried it earlier and i can get to em this should be pretty simple
