if anyone has ideas on issue before I take it in to the shop.
thank you!!
2017 Charger R/T Blacktop
Remote start will not work if the check engine is on. You need to diagnose the check engine light and get the cause fixed.
My 2018 charger rt turns off after I start it with the remote start but when I get inside and press the button it will start fine..a red bolt appears on my screen but then goes away what do I need to do to fix this
If an engine fault is present or fuel level is low, the vehicle will start and then shut down in 10 seconds. Plug a scanner into the car's OBD2 port and see if any diagnostic codes have been logged.
The engine can be started two consecutive times (two 15-minute cycles) with the remote transmitter. However, the ignition must be cycled to the RUN position before you can repeat the start sequence for a third cycle.
Yesterday I tried turning it on n it wouldn’t start..I recently got a mid muffler delete n don’t want that to be the cause of my problem..I had it towed to the dealership and they are running tests on it..I looked up if a mid delete will void my warranty and it says no..what do u think is wrong?I haven’t even paid my first note and i only had it for 3 weeks
