Hope someone can help. I have a 2009 Charger RT. Yesterday when I went to leave work, The ABS, Traction Control, and the Air Bag lights came on. When this happened, my cruise control didn't work. It's the first time this has happened. Later, on the way home, the lights went off and every thing worked fine. This has happened 4 or 5 times after i crank up, but the lights go off after a few minutes. I took it by Auto Zone to have the codes checked but there was no codes listed. Has any one had this problem before? Any suggestions? Thanks.
Hey y'all, watch this!
Sounds like a bad ABS wheel speed sensor, they can be intermittent like that. It will take a scanner that reads advanced codes to see what's stored. Sounds like the scanner Auto Zone used only reads CEL codes (not advanced).
