I'm getting a Check TPM System on the dash followed by the tire pressure reading for all 4 tires. It gos away when I hit the ^ or v button on the steering wheel??????? The air pressure is fine?????
Hope this helps.
From the 2006 LX Service Manual....
If the system detects that the tire pressure in any road tire is going low, beyond the Low Pressure (lamp) ON threshold (see following tables), the TPM system will continuously illuminate an indicator lamp. If equipped with the premium TPM system, a message will be displayed in the instrument cluster. The text message will indicate which tire is low and the display will show all current tire pressures, the low tire will be flashing with its pressure value. This message will be displayed for the rest of the ignition cycle, or until the Low Tire pressure condition has been corrected.
A chime will sound upon initial detection. Once pressure in the suspect tire raises above the Low Pressure (lamp) OFF Threshold, the lamp will go out and the system returns to normal within approximately two minutes time. If a message center button is pressed, the message is replaced by the new message requested; however, if the
Low Tire condition has not been corrected, the Low Tire pressure message will again be displayed. If a system fault is detected, the indicator lamp will flash on/off for 60 seconds, once every 10 minutes.
Sounds like a trip to the dealer for diagnosis might be in order.​
Reactions: Charger Mark
