As the title may state, I am looking to take out some of the equipment standard on the 15+
chargers and make it a bit more comfortable and less “police car”.
I picked up a 15 with very low idle hours and miles, no holes, a detectives car, it actually still smells new!
First and foremost, I would like to remove the column shifter and go to the full center console.
I have a full center console in the car that is fully functional except the shifter. I did some google searching and there are plenty of write ups on the 14 and down but I haven’t seen many/any for the 15 and up. Anyone attempt to hook it up? Can you use the same shifter cable or have to order a new one? Any other issues to be worried about?
Is there a block off plate for the column shifter or does the whole plastic piece need replaced?
Second, I would like to make the back door handles functional. I assume that is as simple as buying the handles and trim? Or does the whole door panel need replaced?
Third, I would like to add the larger screen in the dash. I assume this isn’t as easy as plug and play, this probably takes the dealership to program it in. Any idea of costs associated?
Finally, I would like to add heated seats. I have a power drivers seat but that’s it.
I assume that this is not a simple plug and play either. Any write ups on this process?
Any and all help and direction would be awesome!
