Thread with abunch of info in it!
http://chargerforumz.com/showthread.php?t=52286&highlight=pulling+fuses
SRT8 PCM Reset Technique..but should work on all LX vehicles.
Step 1:
Open the hood of the vehicle and open the covered fuse box on the passenger side of the vehicle.
Step 2:
Remove the following
fuses and set them aside:
11; 14; and 16
These are labeled on the underside of the fuse box cover in a mirrored-layout fashion.
Fuse 16 is a Dark-Blue 15amp fuse found on the far right of the box
Fuse 14 is a Beige color 25amp fuse
Fuse 11 is a Neon Yellow 20amp fuse
Make sure to note the colors...the box lid with the fuse #s reads in reverse and can be confusing.
Side Note on fuse pull:
Some people have stated they have a Beige 25 AMP fuse for #11. Don't understand this..but...don't be shocked.
Step 3:
Insert your key into the ignition and turn the key to "ON" (not "Start"). Wait for the initial sequence of lights and chimes to complete.
Do not turn the key to "Off" until you have reached Step 5.
Step 4:
Without turning the key to 'OFF', turn the key to the 'START' position and hold it there until you hear a single chime. The engine will not attempt to start, this is completely normal. After the chime, release the key from the 'START' position back to 'ON' without cycling the key.
Repeat this step one more time, turning the key to 'START' and holding it until you hear the chime. Once the second chime has sounded, cycle the key back to the 'OFF' position and remove your key.
Step 5:
Return to the fuse box under the hood and reinstall the
fuses, paying close attention to replacing the correct
fuses to their original location. Close up the box, and start your car.
You have now completely reset the PCM's adaptive memory, as well as cleared any stored Diagnostic Trouble Codes (DTC's).
Using this procedure, my car seemed to react a lot better than just the Fuse #11 pull.
1-2 shift was crisper and it seemed more responsive. These are typical things affected by the adaptives, a smooth, sort of slippery (not crisp) 1-2 shift and a relaxed response to throttle, caused by normal daily driving.
