I am selling my harness that I made to swap the 8.4" screen from a 2015 charger into a 2013 charger. I am sure it will work with the other year charger in the same generations. It is not 100% yet, you will need the hvac controls from a 2015 charger, and you will need an HVAC module from a 2015 charger. If you have the factory amp, you can try swapping it out with one from a 2015 charger, or you will have to bypass it. You will get a beeping sound from the audio if you dont bypass the amp. I am selling it for $40.00 shipped in the US. I sold my charger, so I no longer need it. It is plug and play, but you will need to run a few wires from behind the glovebox for the can bus, you may also need to cut a piece behind your dash out in order to fit the larger radio.
Electrical wiring Bag Electric blue Cable Electrical supply
With the newer charger radios, the radio and the screen is all one unit. So you remove the radio from the 2013, this will then plug into the harness on the car, then you plug it into the screen on the 2015 radio.
