OKay so, I have a 2010 Charger R/T R&T and was looking into changing the gears after hitting the dragstrip last night. My question is: Will a carrier from a 5.7 magnum be a bolt up swap? There is one at my local junkyard and I was planning on just taking that out and upgrading the gears in that and then swapping it in, if it is a bolt up swap, then what gears would you guys recommend for best daily driving/drag performance?
