I typically get out and close the door with my key in my right pocket and closest to the button. I press the button and it works sometimes. When it doesn’t I usually press it a couple different times and it still won’t work. So i just use my key. I haven’t really tried to change my body position before when it didn’t work so i guess I can try that and report back.Are you sure you are consistently pressing the button?
Are you angled away from the car with the key furthest away?
Is it always the same fob or do you know?
Do it the same way everytime and let us know
I have my key in my back pack, I am careful to only press with one finger, and I have to press my locks multiple times 6 or7. My fob won't lock my doors, and now my car is requiring me to touch the start button with the fob about every other time. I thought my battery was getting low so I started using my spare fob. No difference. What's up?does anyone else have this issue where you get out of your car and hit the button on the door handle and the car doesn’t lock? The thing is it only does it sometimes, other times I hit the button and it works.
I Changed my batttey in the remote and didn't help. Is it common for both door handle buttons to not work.Mine started behaving like that shortly before the "Remote Battery Low" message came up on the EVIC.
