I thought the charger pursuits had bigger/upgraded breaks? Les Schwab quoted me $700 for the rear rotors and breaks and said there a little more expensive because i need the police package breaksThat should be what you have
Okay thanks man! They put 2 brand new calipers in the quote as well, do I need to replace the calipers? Or should I be fine with just doing the pads and rotors?Rear would be BR8s 13.7 rear vented rotors.
You can find parts much cheaper online. If you go through a shop they always quote HUGE up charges on parts.
If calipers are fine then they don't need to be replaced.Okay thanks man! They put 2 brand new calipers in the quote as well, do I need to replace the calipers? Or should I be fine with just doing the pads and rotors?
I don’t want lesser breaks lol I bought a charger from a dealership and I’m finding all these problems I have to fix. And I don’t got the money to replace everything to an OEM specThe rears will be slightly different but the fronts are the same. Probably charging for trying to get the OEM spec police pads. Even if they were significantly different, why in god's name would you want lesser brakes?
BRAKES. Not breaks. Using the word break with regards to car before it has broken is never good.I don’t want lesser breaks lol I bought a charger from a dealership and I’m finding all these problems I have to fix. And I don’t got the money to replace everything to an OEM spec
Everyone that has read this knows what I meant lol good try tho bud 😂BRAKES. Not breaks. Using the word break with regards to car before it has broken is never good.
Of course we know....doesn't still mean we don't think you're illiterate. 🤷♂️😂Everyone that has read this knows what I meant lol good try tho bud 😂
Are the BR8s considered to be Brembo Brakes?Rear would be BR8s 13.7 rear vented rotors.
No. Pursuit Brakes.Are the BR8s considered to be Brembo Brakes?
Brembos are nice but the price tag on them sometimes gets out of hand. if you are looking at doing brake upgrade, I've seen and heard tons of good things about powerstop and they come in at a lower price point. only difference is you wont have the BREMBO logo on them. The step up from there would be Baer Brakes but they just climb from there.Are the BR8s considered to be Brembo Brakes?
I can attest to the Power Stops. I wanted something better out of our little '15 Jeep Patriot, and this past fall it came time to replace both the front rotors as well as the pads. Because we live in NO. IL area with lots of road salt and corrosion, and it took several shots of PB Blaster and about 20-30 minutes of beating on rusted rotors, I decided to try the PS Z23 series "kit" for the front. Comes with drilled and slotted zinc-plated rotors, carbon-fiber ceramic pads, SS caliper clips and new caliper pin boots. So far, very happy, and hopefully less corrosion issues. Went a similar route with my '06 Daytona last time too.Brembos are nice but the price tag on them sometimes gets out of hand. if you are looking at doing brake upgrade, I've seen and heard tons of good things about powerstop and they come in at a lower price point. only difference is you wont have the BREMBO logo on them. The step up from there would be Baer Brakes but they just climb from there.
