Hi,
I recently put on catless mid pipes but due to the hemi tick/CEL codes they were off the car before they had 30 miles on them. It had the defoulers and all that fun stuff. I put the stock midpipes on I still have 2 codes that my scanner says are permanent and can’t be deleted.The codes are p0159 and p0430. Is there a way to delete these? When replacing the pipes to catless mid pipes one of my stock o2s were stripped. I went to the local store and purchased a new o2 sensor. Just one for the passenger side. I’m not sure if that’s related to the problem, or if I needed to replace as a set or whatever. I imagined the driver stock o2 sensor would be fine seeing how the car has 19k miles. Any help appreciated. Thanks.
2017 Charger R/T Blacktop
If it was not a Mopar o2 sensor good chance that a code would not clear .
Reactions: POWERMAN
