I’ve been looking into mods for my v6 starting out standard have cai and true dual getting he I throttle bod but been hearing about 390 gets I’m curious if you can rn them with the 5 speed transmissions I’ve only ever seen them in the 8 speeds anyone done a 390 gear setup on a 5 speed???
Say what??????????? I'm not sure what you asking but you want more hp from the v6 so you can spend a lot for little return and you want noise or power since a cai will usually just make more noise w/o a tune and you might run it leaner than it should and if run 390 with anything it will gear it lower than w/o it so that's a lot of money and time so I'd just get a custom dyno tune and go from there to see if you want to rn more than that.
