1 - 13 of 13 Posts
I wanted to get a concensus on some information spread throughout several different threads, into one thread... I will update this original post as input and info is confirmed, so all info is in one unified, easy-to-find post.
I have a 2013 R/T AWD Charger
For the AWD platform:
- the rear sway bar is the same as the RWD model, and thus can be upgraded, however this requires dropping the rear cradle
- I have not gotten confirmation on any compatible front sway bar upgrade aside from maybe the stock pursuit sway bar? V
- Have not been able to confirm compatible sway bar end links for AWD
- STP suspension upgrade is not compatible
- Coilovers options include: BC https://www.bcracing-na.com/product/ds-series-coilover-dodge-charger-awd-2007-2016?gfid=p3293-c24861
- Any other brand shocks/struts for improved performance?
- Front and rear shock/strut braces are same for RWD and AWD
- Subframe connector same for RWD and AWD
Please add your input on what else is available, and what has or hasn't worked for your AWD's.
Thanks fellas
Reactions: MadMaxx
Good list man, don't forget Front and Rear Strut Braces...believe they are the same RWD/AWD!
Apparently can't edit original post, so this is my updated list:
REAR SWAY BARS
- the rear sway bar is the same as the RWD model, and thus can be upgraded, however this requires dropping the rear cradle (Hotchkis, Whiteline, Petty's Garage, Eibach, etc)
Whiteline: http://www.speedlogixstore.com/product-p/bcr15z.htm
Eibach: https://fasthemis.com/i-23835502-eib...tegory:1204066
Hotchkis: appears that rear bar is not sold separately
Petty's: https://pettys-garage.myshopify.com/...-rear-sway-bar
FRONT SWAY BARS I am unaware of any compatible front sway bar upgrade aside from maybe the stock pursuit sway bar? (Not confirmed)
END LINKS
SUPER TRACK PACK
COILOVERS
- Coilovers options include: BC https://www.bcracing-na.com/product/...d=p3293-c24861
SHOCKS/STRUTS
SHOCK/STRUT BRACES
- Front and rear shock/strut braces are same for RWD and AWD (Speedlogix, Mopar, Petty's)
http://www.speedlogixstore.com/category-s/2214.htm
https://pettys-garage.myshopify.com/...ns/brand-parts
SUBFRAME CONNECTORS
Speedlogix: http://www.speedlogixstore.com/produ...x-306-5014.htm
Thanks fellas
I need Shocks/Struts and am having a hard time. Mopar is out and everyone seems to be back ordered WTF. Nice post thank You
Unfortunately my good friend, I believe we're stuck with either KYB's or doing coilovers, I could be wrong though...which is the predicament that I am in and going the coilover route...
1600$ for BC kit coilover and front swift springs. I guess its that or wife will trade it in LOL
It's been a while since I've been on the forum but yes the stock AWD police sway bars are an upgrade for our Chargers. I'm running the AWD police front and rear sway bars on my Charger.
Do the Kyb's handle the drop of the eibach pros well? As far as bottoming out and longevity... been struggling to find any aftermarket struts and shocks to accommodate these shitty Midwest streets
BUMPITY, BUMP. If I don't hear from anyone, I'll assume no one has done it. I have print outs for my car 2011 R/T AWD and a 13 RWD, and will be comparing stock part numbers. I'll post up results when I'm done for anyone else that might be interested.
1 - 13 of 13 Posts
