I recently started mod'in my 2014 Charger. I have read a lot of posts in the how to section about this mod. I tried it yesterday and it did not work. The gen 7 Charger's have a small circuit board with an LED that produces the blue light in the cup holder ring. I soldered a LED to the wiring harness and put it all back together with no light. If anyone has an idea or answer to help fix this issue I would appreciate it.
***Update*** I found a LED that has wires instead of metal leads. I was able to get the wired LED hooked up and working, but I could not get it to light up the ring in the cup holder. Maybe the LED did not have a wide angle? Any suggestions?
I do not know this personally but you might want to check the Interior & Exterior Electrical section. Also a quick search before hand might save you some time. I do recall seeing a long time ago of someone changing the lighting of their cluster and the shift lighting. If I recall correctly there was a lot of soldering involved. A very unique mod if you can pull it off as well.
Yea, I've searched the lighting forum for help, but couldn't find anything for 2011+. I have tried to solder LEDs and cannot get it to work for some reason. I may have to out source this mod. As much add I hate to do it, I might have to do it.
Again I have come back to this mod and no dice! I tried a couple different wide angle led's with no luck. Any info into what type of led or how it was installed would be appreciated.
I can get it to turn on, but when I put it in the cup holder you can't see it. Not a wide enough angle bulb? Need specific type?
Related Threads
Dodge Charger Forum
1.8M posts
46.2K members
Since 2006
