1 - 20 of 28 Posts
Having problems with hands free Bluetooth, it won’t pair up with my phone and I get this screen. Is the Hands free Bluetooth module KAPUT ?
I think there's a unpair option in the "Settings" menu. You can clear paired phones and then pair the phone to reconnect. Worked for me in the past. Other owners have reported the Hands-free Module worked again after they unplugged/re-plugged it. The hands free module is located under the instrument panel to the left of the steering column mounted to the amplifier bracket.
Tried going to settings menu but nothing happens when touching phone/bluetooth option bar. Also unplugged hands free module, made no difference.
If you have a OBD2/CAN scanner that can scan all codes (e.g. BlueDriver) you can scan to see if U0197 is logged (U0197-00-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE). Otherwise, it's a trip to the dealership so they can run their diagnostics.
Reactions: Tomturbo
I lost mine in my 2013. The battery disconnect worked a couple times but had to replace it. Its pretty common for this scenario.
Th3 newer ones are improved and less likely to fail. It should be a different p/n.
Reactions: Tomturbo
Coincidentally, mine failed while giving someone a jump.
Reactions: Tomturbo
Welcome to the club
Reactions: Charger SXTease
This post is a few years old now, but just got a 13' Charger R/T. Thought it was a great deal 41k miles 18k OTD. Noticed bluetooth handsfree wasn't working. Dealer said most likely needed to be flashed. Now they're saying I need a new module. They're trying to charge $725.
For those that have done it. Was this the module you ordered by chance? Thanks all!
It's common for them to fail, I got mine on ebay or Amazon and installed it myself.
HFM (hands-free module) Removal:
Disconnect and isolate the battery negative cable.
See images below for the following ...
Remove the steering column opening cover (1)
Disconnect the HFM electrical (1) and USB connectors (2).
Remove the HFM retainers.
Remove the HFM (4) from the mounting bracket.
Cover
122135
HFM
122136
Installation is the reverse of removal.
Reactions: Mschneider
Much appreciated!!! Yeah on top of the $725 for the part, they were gonna charge another $100 for labor. If it's a few screws and some cables. Easy enough!
Glad to see you got it fixed. (y)
Having problems with hands free Bluetooth, it won’t pair up with my phone and I get this screen. Is the Hands free Bluetooth module KAPUT ? View attachment 92086
Has anyone opened up a module after it failed to work to do some pc board level troubleshooting? I can temporarily connect my iPhone after disconnecting the car battery, but then the module drops out. During the Christmas break (when I have time in an effort to save a few hundred bucks) I’m going to try to confirm my suspicions and see if a Lithium battery coin cell Is end of life or a single super cap has failed. May end up replacing any/all electrolytic capacitors. Has anyone opened up a failed module? Is anyone willing to part with a broken one?
I glanced in side and did not see any major components like a bigger cap to replace. I did have the idea to do what we use to do with the PS3 fatties when they yellow lighted and heat the board up to do a solder reflow in attempt to fix it.
Thanks for the response! I have a Seek Thermal imaging camera I will use - power it on from the bench and see if anything gets hot - Did you see a coin cell lithium battery on the board ?
1 - 20 of 28 Posts
