Has anyone replaced the differential axle seal?
Discussion in '6th Gen Dodge Charger' started by akobuck, Mar 26, 2011.
  1. akobuck
    akobuck New Member Military
    May 24, 2008
    53
    Media:
    2
    5
    Hampton, VA
    Vehicle:
    R&T R/T
    Trim?:
    Daytona
    Color?:
    HEMI Orange
    I have a leak from the passanger rear differential axle seal. The Haynes manual actually uses the word "Easy" to describe this repair. One part I'm not sure about is how easy it is to take the axle out after you drop the differential. Also, other than the seal itself and the nut that holds the axle to the hub assembly, what other parts need replaced? Any info would be helpful!
  2. burkdadhemi
    burkdadhemi Senior Member Photo Winner! MOTM Winner!
    Mar 6, 2007
    14,779
    Media:
    56
    713
    al
    Vehicle:
    06 Charger
    Vehicle Year:
    6th Gen - 2006
    Trim?:
    SRT8
    Color?:
    Brilliant Black
    Bump for any info
  3. hawkeye4077
    hawkeye4077 H-D 883 IRON MOTM Winner!
    Aug 30, 2008
    12,781
    Media:
    56
    Albums:
    3
    634
    I've been everywhere man
    Vehicle:
    RAM 1500 4X4
    Trim?:
    SE
    Color?:
    Bright Black
    Hey ya go bro
    REMOVAL
    CAUTION: Never grasp halfshaft assembly by the inner or outer boots. Doing so may cause the boot to pucker or crease, reducing the service life of the boot and joint. Avoid over angulating or stroking the C/V joints when handling the halfshaft.
    [​IMG] 1.With vehicle in neutral, position and raise vehicle on hoist.2.Using 14mm hex, remove axle drain plug (1) and drain rear axle fluid as needed into container suitable for fluid reuse.3.Install drain plug (1) and torque to 60 N·m (44 ft. lbs.) torque.
    [​IMG] 4.Remove rear exhaust system from catalytic converter clamps (1) to muffler and tailpipe assembly.
    [​IMG]
    NOTE: To release wheel speed sensor connector from body wiring harness connector (1) in following step, move retaining clip (2) as indicated here, then pull sensor connector (3) outward.
    [​IMG] 5.Remove sensor connectors (3 and 4) from body wiring harness connector (1) located in luggage compartment floor pan (2).
    [​IMG] 6.Apply alignment index marks (3) to the propeller shaft rubber coupler (1) and axle flange (2).
    [​IMG] 7.Remove three propeller shaft coupler-to-axle flange bolt/nuts.8.Position an extra pair of jack stands under and support forward end of engine cradle to help stabilize vehicle during rear suspension removal/installation.
    [​IMG] 9.Position under-hoist utility jack or transmission jack (2) under rear axle (1). Raise jack head to contact rear axle and secure in place.
    [​IMG] 10.Remove both rear (2) mounting bolts fastening crossmember (1) in place.11.Slowly lower crossmember using jack until crossmember is at a comfortable working level to access rear axle-to-crossmember bolts.
    [​IMG]
    NOTE: Do not pry on the axle halfshaft slinger. 12.Using suitable prybar (1), partially disengage halfshafts (2) from axle assembly.
    [​IMG] 13.Remove the front mount bolt cover (1) located at the top of the axle carrier (2).
    [​IMG]
    NOTE: The nut will turn free at the at the top of the axle carrier, it will need to be held with a deep socket during removal. 14.Remove rear axle front mount bolt (1) and nut (3).15.Use only hand tools to remove two rear axle-to-crossmember bolts (1).
    [​IMG] 16.Carefully lower rear axle. While lowering axle, separate propeller shaft from axle and support with suitable rope or wire (1).
    [​IMG] 17.Lower axle just enough to remove both halfshafts one at a time. Shift axle assembly in one direction, compressing one halfshaft while removing the other (1). Use caution to protect axle seal and journal when removing axles. 18.Remove axle assembly from vehicle and transfer to bench.
    REMOVAL
    [​IMG] 1.Remove halfshaft(s). 2.Using suitable screwdriver (1), remove axle shaft seal (2).3.Visually inspect halfshaft seal journal for damage (excessive seal groove, nicks, scratches, etc.). Replace halfshaft if necessary.
  4. Kpetty105
    Kpetty105 New Member
    Oct 4, 2017
    1
    0
    Gender:
    Male
    Oregon
    Vehicle:
    Charger
    Vehicle Year:
    7th Gen - 2011
    Trim?:
    R/T
    My differential went out so I'm planning on taking it out and getting it fixed. Is the reinstall the same and taking it out or do I need to take the calipers off and take the axle nuts off the hit them with a rubber mallet to seat them
Share This Page
