ever had a problem with installing halos themselves? I cant afford to send my lights to AAC and be without my car. Im wanting to tackle this project myself.
Never had a problem. You can do it yourself, just read through the instructions posted on this forum. Keep in mind you will be breaking the headlights apart, the plastic will be making all sorts of great cracking noises. Take your time and anticipate a day or two of not driving since you will take the fascia off and then need time to bake the headlights, use a screwdriver to break it open, glue the halos on, drill holes for the wiring, attach the inverter (if using ccfl), and using silicone to seal everything back up. Use gloves so you don't get fingerprints on the inside of the headlight.
It may seem overwhelming at first but it is not hard just tedious. The results are worth the effort.
Thanks. I will try to knock this project out this weekend
On a scale of 1-10, 10 being most difficult I give it a 6. Just give yourself time, breathe and relax.
