What's up Dodge peeps! How do you adjust the headlights on a 2016 Dodge Charger. I just installed a hid kit and they are not pointing in the right direction.
There's usually a hole in the engine bay, right above the headlights, where you use a torx bit or Philips to adjust. The actual adjustment will be on top of the Headlight Assembly/Housing.
Here's where the vertical adjust would be on the '15+
