1 - 17 of 17 Posts
for albert
Albert, i'm having the same HID lights/ low Beam fuse problem, so you are saying swap a red 10AMP on the far left side in the trunk, or far left side of the fuse box in the trunk? there about 3 or 4 red amps to the far left side of the fuse box.... which one exactly?
Yes it's in the trunk on the far left side and it's a red 10Amp.
Does anyone know where the fuse for the left headlight and marker light are out. The high beam light and turn signal work. Any help will be gladly appreciated
In the rear fuse box (in the trunk) there are two exterior lighting fuses (40 amp). They're cavity 6 & 7. I don't know which lighting circuits are associated with each fuse.
1 - 17 of 17 Posts
