2007 Charger RT. Driver side headlight will not stay on. I changed out the bulb and even replaced the switch. Its only the one bulb that comes on and then turns off right away. This happens with the hi-beams on or off. Anyone have any ideas on what could be causing this? wiring harness? please no...
Try wiggling the wires and see if that turns the bulb on. I had a similar issue with my 09.
The hot wire for bad connector was corroded so I just re-wired it to good side. One power source to both low beams. Works 100%.
