got a 2010 and the heater/ac fan blower wont turn on. thought it was the fuse..nope. replaced the resistor...nope. bought a new fan blower...nope. is there a relay in that fuse block in the trunk? think maybe my control panel itself may be bad, because the AC light and the rear defrost lights dont come on either. i am at my wits end. any tips will be greatly appreciated!! thank you all
Check the connections on the back of the HVAC module, if that doesn't make a difference then your module is fragged.
There's three fuses and a relay in the rear fuse box (trunk) that are related to the HVAC system.
Fuses: HVAC blower, HVAC module/cluster, and the HVAC module/In car temp sensor.
Relay: HVAC blower
