1 - 15 of 15 Posts
Putting up for sale a brand new, never installed, Hellcat rear spoiler from spoiler kings. Bought this on January 23rd and planned to have it installed along with several other pieces my body shop is working on for me, but decided I personally really didn't prefer it to the stock, more subtle, spoiler.
From the seller:
This spoiler is the same size and shape as the 2015 - 2017 factory Hellcat spoiler and will also fit the 2011 - 2014 Chargers, it does not have the same hole pattern as the pedestal style factory spoiler.
IN PRIMER AND READY FOR PAINT
Wrapped and boxed and comes with everything that came in the package (double sided tape, etc). Asking $60 plus shipping.
2017 Dodge Charger R/T
any pics of the actual spoiler as I'm definitely interested if it mounts to my 2017 without having to drill holes
Discussion Starter · #3 · (Edited)
I can take pictures if you really need me to but I had wrapped/taped it back up in the styrofoam shipping stuff when I decided not to install it. It's exactly what you see above, just primered/not painted. You do not need to drill holes to install it, just know that there will be holes in the outer side areas because it's not a 3-piece like the stock R/T spoiler.
People use little black plugs and silicone to fill them, which you can buy from any Home Depot/Lowes, and some people even paint the plugs body color. The only time you see those is when you have the trunk open though. There are plenty of youtube videos you can check out of people who have done the spoiler swap to see what I'm talking about. Hope this is helpful.
Oh ok, yes I know of the install and everything just worried on whether or not it would align with the current holes already in the trunk lid from my factory spoiler. Some of the aftermarket spoiler required for holes to be drilled but if you say the line up, i definitely want to get it from you. How much with shipping to 30096?
Discussion Starter · #6 ·
Well I should be clear, I was told they do and bought it under the same pretense. I have no reason to doubt that because it's the same spoiler bought by a lot of people I came across on youtube/IG, etc that all said it was a perfect fit. Only reason I can't confirm 110% is because I never even removed my current 3-piece.
I will check shipping tomorrow and let you know. In case you're able to check before me, my zip is 07039
Sorry for the delay. FedEx quoted me $39 and change shipping to that zip code. So basically $100 total if you want it
Sorry for the delay. FedEx quoted me $39 and change shipping to that zip code. So basically $100 total if you want it[/QUOTE
Hey bro! Sorry about the late response. I’m gonna actually go ahead and go OEM on the spoiler, but good luck with your sale
Discussion Starter · #12 ·
Does it just stick on with double sided tape or does it require you to drill
New holes?
I do not know anyone who has drilled new holes to install it. It comes with double sided tape and my understanding is you use the original holes in the middle portion of the trunk to bolt it down. You do not use the holes on the outer portions of the trunk above the turn signals (obviously)
Discussion Starter · #15 ·
Still have it. I'm not a shipper so I can't quote you shipping costs. You're welcome to quote it yourself - I'm at 07039 (NJ) and the box dimensions are about 13" x 3" x 65". Probably weighs 15lbs or so. Will take $50 plus shipping
1 - 15 of 15 Posts
