1 - 11 of 11 Posts
I keep getting a message on the radio screen that says. " turn vehicle to run please wait while VIN is verified. Let it sit for a while like that nothing happen it also says on the instrument panel to push clutch to start it doesn't have a clutch
Does the car start and run normally if you press the brake pedal and push the start button to the Run position?
The police vehicles have a Vehicle System Interface Module (VSIM) installed. They remove this module and revise the Vehicle Configuration information in the BCM (body control module) when they decommission the car for sale to the public. The BCM stores and compares vehicle configuration data with other Electronic Control Units (ECU) in the vehicle.
They may not have done a complete job of revising the Vehicle Configuration information. You need to visit your local FCA/Dodge dealership to get the software updated. Or ... if everything is working OK, live with the misleading start-up messages.
No it will not do anything this is still a police vehicle we are upfitting it for them they bought 3 used ones nothing has been done any different than the other two but this one is a dud lol it won't start at all
Did you ever find a solution? Just bought a 2013 and having the same issue.
Welcome, from Pittsburgh!
OP was only here for two days.
Upfitter731
Registered · From Greenback tn
Joined Apr 11, 2017
Last seen Apr 12, 2017
I don't expect he'll answer you. Hopefully, the upfitter guide djalbin posted above may have something useful for you. Good luck!
He/She posted on the other forum also.
1 - 11 of 11 Posts
