My center racetrack light doesn’t light up when the trunk is closed but when I lift the trunk up it lights up do I need to replace the whole center piece ?
Sounds like the wire is cut somewhere and only connecting when you lift. Check the wiring and see if if it is cut or loose somewhere.
What trim in 1969 had the track lights?
Hi Charger97,
Sorry to hear of the trouble you’re experiencing. If you decide to address this concern with your certified Dodge dealer, please feel free to send us a private message. We would be happy to provide you with an additional layer of assistance for that process.
Rob
Dodge Cares
Thanks I was thinking the same thing I will check the wiring on the trunk and do i need to take the center piece off ?
