I got a 2013 charger Daytona the button for the fuel door release is jammed or broken need help to figure out how to fix it
Fuel door release is electrical. Check fuse #23 in the rear fuse box located in the trunk (10A red fuse). It should be labeled as the "Fuel Door / Diagnostic Port" since it's the fuse for both the fuel door release and the OBD2 diagnostic port.
Until you can get it properly repaired, I'm pretty sure you can manually open the fuel-access door from inside the trunk to fuel up. I believe the release is directly behind the fuel door.
Checked the Owner's Manual. There's an access cover (marked) in the trunk with a cable inside to manually open the fuel door.
